So how this mechanism works is that center piece attached to the wire is supposed to move down and up through the lower black part? I'm not meaning the secondary latch mechanism that goes left right to loosen seat in the latch. I am meaning the cable is supposed to move up down in the bottom black part which then triggers the latch in?
I see an example on the "other" website.
So tightening the thing all the way up should yank it loose, by pulling the cable free in the bottom black part? I was hitting it with a hammer trying to loosen it but I wasnt hitting it too hard because it was past 9pm and neighbors needs out weighed the needs to break this loose.
Hammering it upwards the same direction tightening the winch would do, aka hitting the very bottom of the piece of cable that is sticking out.
I dont believe mine is rotted to the point that I need to replace it. the cable I can see is nice and new looking. I just need to get this stupid latch free then apply tons of grease.
I see people saying lithium grease... Why not axle grease? I have tons of that! I'll drench the whole thing down! I'll fill the whole channel with axle grease!!
The screwdriver prying thing aint gunna work on this, however pinning the screw driver to the mechanism that wont move and hammering it should knock it loose, eventually. I PB blasted the hell out of it and filled the center area several times. meaning spraying into the channel of the latch which comes down into the black area bottom and fill sit all up to break that rusted area up too.
