- Dec 12, 2011
- 4,666
So with this ongoing occasional noise I get in the valvetrain, something has been constant lately and it sounds like some clatter at or around 3200 RPM during normal acceleration. If I accelerate from a stop and pass through 3200 RPM with a shift happening around 3500 RPM, I get a light racket in what sounds like the valvetrain. After I'm at speed, if I downshift to try to duplicate this it's quiet, it's only as I'm accelerating from a stop and it seems to be in 1st and 2nd gear.
At first I thought maybe a flexplate as the torque is higher at a lower ground speed and could affect the noise if it were cracked. However it seems to be coming from the top of the engine.
The other option may be a cam phaser...I'm curious what the PCM commands for the VVT at this speed from a stop...which seems to be right before a shift but not always will it shift if I have a high throttle setting but the noise is generally still present. If I go WOT sometimes I don't hear anything and sometimes it's very brief.
Sometimes I hear the noise at idle and with raising the RPM slightly it goes away completely.
If at a stop, I can raise the RPM to 3200 with no noise.
Just curious what the cam phaser is commanded to do under these circumstances....if anything.
