Water Leak Rear Hatch
ChriSS K
243
I noticed the floor was wet on the drivers side rear. I can see it wet in the rear drivers side corner of the headliner. Any common causes to this leak? I double checked the gasket where the main wires go through since I pulled it to install the rear camera. Unless someone knows of a common leak I'll just pull the panels and run the hose to see whats what. Thanks
10,747
Check the screws for the roof rack rails, see if any have backed out on you and gotten loose. Water can get through to the headliner from the screw holes if there's a poor seal.
Reactions: Matt and Wooluf1952
Wooluf1952
2,663
Milwaukee, Wisconsin
^^ What Carlton said^^ IIRC, there were reports of the cubby hole under the rear floor filling with water from that.
wentzben
