Vibrations and growling from Underneath!!!!
zamimj222
53
Illinois
Hope someone can help me figure this one out...
I changed the trans fluid and filter along with both diffs and the transfer case. I made sure all the fluids were to their respected full levels. I had used Dexron III instead of Dexron VI so I did flush the whole thing through the trans / radiator tube. I now have a new problem. Around 35 MPH and above there is a growl from underneath that is louder that the engine exhaust. It is accompanied by a slight vibration in the gas pedal. After letting off the gas, it seems to hang up, as if the cruise is on, at the speed for a few seconds before starting to slow. The noise does go away after slowing back down to around 35 MPH.... Any ideas?
Wooluf1952
2,663
Milwaukee, Wisconsin
Check post #5 from your other thread: http://gmtnation.com/f23/transmission-whine-after-servicing-910/#post19502
MEHMET ONUR
