On my 2007 Envoy 4WD I have an intermittent problem - while driving along ( I think its when I hit a bump too), a sudden vibration/grinding noise starts; It seem like at the front and low down; almost like ABS grinding but no feeling through the pedal when I brake.
No feeling in steering wheel or accelerator pedal either- just the noise.
The first time it happened it was quite noisy/rough and I braked quickly in case something was falling out. The noise only stopped when the car stopped. After a thinking session I started moving again and no noise- all was fine.
It was fine until a few days later; same thing - I immediately braked and the noise stopped. Again about five minutes later and I pulled over and the noise stopped- all was fine when I moved away.
A week went by then it happened again but this time not as loud. The noise stopped even while I was slowing down. A week later- the noise started again when I hit a bump in the road (most roads in Winnipeg are bumpy) I almost didn't hear it because it was not as loud and the general road noise/traffic masked it, but I recognised it nonetheless; this time it stopped after a few seconds even before I could brake much and so I continued driving.
It has recently done it a few times, maybe about a week apart, and stops on its own a few seconds later while I start braking.
Its very intermittent so difficult to track down.
I am considering:
one of the front axle shafts (with CV joints), because if I grab the inner end and rock up and down there is play with a clank sound - although no noise when driving and no play in rotation and no clicking from the CV joints - is that normal? (No play at outer ends)
Also maybe the front differential? However - wouldn't it make the noise all the time?
It still seems like a bump triggers something, then it stops after a few seconds, so can't be bad, can it?
Maybe even the cooling fan bearing? Some members have mentioned vibration from that, although surely that would give a continuous noise, wouldn't it?
The front differential rear seal has a slight sweat/leak but nothing bad- the fluid does not drip onto the garage floor for example. 4WD works fine when I use it and I have had regular scheduled fluid changes whenever I take the car in for oil change.
I also read about wheel sensors maybe being dirty or having corroded connector pins and causing ABS to kick in on its own, but then wouldn't the brake pedal feel like the ABS was operating? It doesn't.
Maybe someone has had exactly this issue and solved it?
I am considering:
