I had a MIL going on and off on my Envoy XL with the 4.2 6 cyl engine a couple years ago.
The code was P0014. Exhaust Camshaft Over Advanced.
I changed the CPAS with a new GM part, and the problem seemed to subside. Light went out. The old one had signs of sludge on it when replaced.
Then the code returned.
I added a quart of Rislone in case the problem was engine sludge related. I left that in for one oil change cycle.
The problem seemed to subside again.
The Malfunction Indicator Light would occasionally come on, I pulled the codes and the were always that same code.
I never noted any running problems, in fact the only difference was the DIC would report dramatically better mileage when the light was on.
I liked the gas mileage increase!
For the next several oil changes I followed the same procedure, the next change I added a quart of Marvel Mystery Oil, and the next I added a can of Sea Foam. Trying different things to scavenge sludge
I received occasional MIL indications, and then it would go off on it's own.
For quite a while I didn't see any problems at all, maybe for 8 or 9 months.
Then last week things changed. I noticed a slight stumble at idle, and later that day I got a misfire and a blinking MIL. It went away and then got worse. I pulled the code, same one.
I took out and cleaned the CPAS with Carb cleaner. It wasn't too dirty but I cleaned it and put it back in.
The misfire reoccurred.
Yesterday, I did an old school engine flush procedure, dumped the oil and added ATF and let it run at idle for 1 1/2 hour, then changed the oil and filter.
I still have a slight rough running at idle. It stumbled but didn't die at a stop light last night.
No codes were there today, I just checked. The stumble and near stopping didn't store a code.
I am going to throw another CPAS at it this afternoon to see if that solves the problem.
I changed the spark plugs 3 months ago, I used the Bosch Platinum plugs.
Does anyone have any ideas to troubleshoot this problem?
