Uneven brake wear
kdannyk
85
Ever since I replaced my wheel hub I'm getting uneven break wear. There will be two spots all the way across the break pad that doesn't seem to be touching as much. I made a picture and attached it bellow of what it's doing. The yellow circle would be were the pad isn't touching and leaving a high spot on my rotor. When i'm driving down the road I can hear my brake pad/ Hub squeak with out touching the brakes.
Pic did not work.
Are your pins/slides greased? Did you get any grease on the pad or something that might have affected the pad?
kdannyk
85
There's no grease on the brake pads. The pins slide are greased. They seem to slide fine.
Did you push in the caliper pistons when you removed it for the hub swap? Could be stuck or cocked piston.
kdannyk
85
It there are two ridges on the entire length of the break pad that are not touching.
Matt
4,022
Funny, I've got the exact same thing happening with my passengers side, inner side. Noticed it when Regulator and I changed the CV axle last week. No idea why it happened when I changed pads this time. When I changed pads and rotors last time, there were no issues.
coolasice
1,019
Northern Maine
Possible to snag a photo? Could the pad have shifted when everything was reassembled?
Eric04
392
West Michigan
Have you inspected your rotor?
Good call by Mounce. I just had a rotor develop a hard spot on another vehicle I own. Threw a ton of noise when rolling at low speeds. Worst part was that the pads/rotors had less than 10,000 miles on them... Anyway, pull the rotor from the offending side and have a good look.
Mounce
13,667
Tuscaloosa, AL
Only reason I brought that up is because I have no clue how uneven pad wear like your case could be blamed on a wheel bearing. Wheel bearing won't keep two parts of the pad from wearing. At least I don't see how it can. Maybe grab a pic of the offending pad for us when you have it apart.
When I changed my front brakes, both inner pads were worn out but the outters still had 1000+ miles to go.
Is the hub seated fully? If it was in the bore crooked somehow it could make the pads not ride evenly on the rotor. Basically stuff would be out of parallel.
Could also be a hard spot in the rotor casting as mentioned that caused some weird pad wear, that then just gets worse as time goes on.
Tiggerr
1,324
Perrysburg, OH
If the old bearing has slop in it it could've masked the underlying brake issue. With the new hub being right and true, now you can feel it. Or the uneven wear could've been caused by slop in the bearing originally. Doesn't take a lot. If that rotor had just a tick of wobble to it with the old bearing, that'd do it
Firebaugh86
