One thing after the next lately with my Envoy (2005 XL, SLT, 4.2L, 4WD, 197000 miles). Replaced the temp sensor/thermostat last week and discovered one of the drivers side CVs was blown. Ordered an axle, and when I got under there, I discovered my new thermostat and the transmission were both leaking. Got the axle done and the thermostat resealed, but the transmission leak is out of my league.
Took it in yesterday, and the diagnosis is that the transmission pump seal is leaking. I took it to the dealer since I don't really have a local mechanic I trust. They want $1200 for the pump seal. I called around to some transmission shops for 2nd opinions and they are consistent in that they recommend a rebuild given the mileage and want $1500 +/- or so depending on the shop. Their logic seems to be that replacing only the pump seal doesn't come with much of a warranty, whereas a rebuild will have a 1 year 10-12k (one shop claims 1 year unlimited mileage) warranty.
I've been lucky with transmissions in my life so far and have no experience with this. My brother has had 2 transmissions rebuilt in his life and had nothing but problems. His were both failing prior to the rebuild. Mine shifts and drives completely fine.
I did ask the dealer about a rebuild, but they want over 3k. The truck's barely worth that so I've ruled that out. I would like to drive this thing another 2 years (likely around 20k - 25k miles based on the last 2 years) if I can keep it running that long. A newer truck will certainly cost me more than any of the above mentioned prices. I'm willing to spend the 1200 or the 1500, but I'm not sure which way to go.
Ideas? What would you do in this situation?
