Hi All,
I am trying to troubleshoot my trans failure and the symptoms I find on the net seems to fit both a failed forward sprag or a failed Shift Solenoid B (or communication to it).
I believe symptoms for both are that 3rd/4th are only available after the vehicle is moving, must start out in 1 st/2nd. Since 3rd/4th work after the vehicle is moving I have ruled out 3/4 clutch pack (hopefully that is correct).
Details/background/symptoms if it matters:
2006 Envoy Denali, 119k km reasonably well maintained.
Trans oil on dipstick appears excellent in colour/clarity, no burnt odour
Trans fluid/filter changed @ 105k km last summer by dealer
Good quality trans cooler installed just before fluid change
Tows 4800lb loaded travel trailer a few times a year. Trans temp monitored during towing (only in 3rd) by ScangaugeII typically 165-185°F ambient temp/hills dependant
No prior symptoms. Today truck made a lurch after turning a corner and seemed a little sluggish (according to wife) but drove fine rest of way to work. At lunch, she pulled to edge of parking lot, waited for traffic then no forward gear (rev like neutral). Selecting 2nd gets you going thereafter 3rd/OD work. Reverse works.
No CEL.
Any assistance is appreciated.
No CEL.
