I noticed last week that the overflow tank is bubbling a few minutes after the engine is shut off. It doesn't seem to do it while the truck is running and the gauge shows the temp is a tick past center. I hooked up my gauge and it shows between 210 and 220. It does get to 230 occasionally when pushed hard, but drops back down when let off.
Some history:
Bought the vehicle second hand from father-in-law. Just reached 200k so am doing a full service on the vehicle. The upper hose was replaced prior to my ownership because it was leaking and was topped of with green coolant by mechanic who was old school and said not to use Dexcool. Temp shows fine and heater blow hot when warmed. I decided to flush the old coolant out because it was a mix of green and dex and filled it with water to flush the system. When the vehicle was to temp I noticed the upper hose was hot to the touch and the low hose was cool. There also does not seem to be any flow though the hoses. I disconnected the upper hose and let the engine run for a few seconds and no water flowed, it just seeped up from what I guess was expansion from the heat.
Is there any way to test to see if the pump is working? Shouldn't there be some flow even with the thermostat closed? I know that on my SBC I could tell that the pump was working by disconnecting one of the heater hoses which bypassed the thermostat. I would just take it out all together to eliminate that from the equation but that doesn't seem to be an option on these engines.
Oh, there might also be a problem with the fan. It doesn't seem to kick on full when the coolant is bubbling like my last Trailblazer did. But that might also be because the ECT shows normal temps. Could it actually be showing cool because the water in the hose near the thermostat is cool? The sensor is in the same pocket as thermostat, but I would think the water inside the engine would be hot in there if the water was not flowing.
I do have a spare engine that has a ECT I can use that I know works and have a pump in that engine, but I don't have the tools to get the stupid clutch off. I also have a new thermostat for that engine, but it is a Duralast one and I have read that only the Delco ones should be used.
Some history:
