Hello To All Who Dwell at GMT Nation!
This first post of mine is going to be a DOOZY... It all stated back in December of 2014 and the concern was my son complaining of a serious misfire in the 2002 Chevrolet Trailblazer LS. I ran some OBD II fairly sophisticated checks with a good tool... but ultimately I made a more conclusive diagnosis (Bad/Leaking Valves) by holding a strip of writing paper over the exhaust tail pipe and when the strip of paper fluttered violently and was suddenly sucked back up inside the pipe, it was pretty clear to me that after 240,000 miles, this white SUV was badly in need of a valve job.
What follows covers more than just replacing the engine head on this unusual motor and while I am not trying to discourage anyone from doing this repair... unless you are possessed of much patience, much money and have at least a seasoned amount of mechanical skill... it might be worth paying to have a qualified mechanic do the job. Just by virtue of the technical difficulties from the outset... this repair will become a long road...with no turns in it.
These are the requirements in my opinion for doing the best possible repair in this situation... but I realize these might have to be paired down for obvious reasons:
Manuals and Other References:
GM OEM Factory Carline Series Service Manuals (Full Set) Pale Blue Covers
2004 Timing Chains and Gears (1992-03) (Timing Chains & Gears: Domestic & Imports) Alldata
Haynes Service Manual 2002 Chevrolet Trailblazer, Etc...
YouTube Videos where available
Lubricants and Sealants:
Mobil 1 Oil with K&N Oil Filter
Permatex 81950 Ultra Slick Engine Assembly Lube, 4 oz.
Genuine GM Fluid 12378521 RTV Engine Sealant – 3 - 5.3 oz. Cartridges Case Sealer
General Maintenance: (Work Done By Me So Far with Parts I Purchased NEW))
K&N Air Filter E-1009
New GM Throttle Body 2002 only TrailBlazer Envoy Bravada 4.2L 25312095 TPS
Fel-Pro Fuel Injection Throttle Body Mounting Gasket 61337
Right+Left Side New Headlight Lamp Set of 2 Chevy Clear lens Halogen 2002 Pair
A3C10 02 2002 03 2003 04 2004 05 2005 06 TRAILBLAZER AIR INT RESONATOR OEM
AC-Delco OEM PCV Hose - Trailblazer Envoy Rainier Bravada w/4.2 (24577310)
AC-Delco OEM GM - ISUZU - OEM IGNITION COILS (6) -Premium Quality
General Motors 2.8L / 3.5L / 4.2L Coil on Plug Boot / New Ignition Coil Boots (6)
Stabilus Trunk lid Lift Support New Chevy Chevrolet Trailblazer SG230044 (2)
Envoy Trailblazer Rainier Ascender Left Driver Rear Door Window Motor Regulator (TBD)
AC-Delco 12578069 GM Original Equipment Crankshaft Balancer Kit with Washer (TBD)
Transmission Replacement: Completed by me...
2002 Chevrolet Trailblazer 4L60E Transmission, 4.2L, 2WD, w/ Converter, Re-man 3yrwty
USA Heavy Duty Bushing 15785087 Shifter Shift Cable Trailblazer Chevrolet
Dorman 917-615 Speed Sensor
02-09 Trailblazer Envoy 04-07 Buick Rainer 4.2L Motor & Trans Mount Set 3-PCS
AC-Delco 4L80E 4L85E Cooler Line Fitting Center of Case Rear 1997-up New OEM
AC-Delco / GM 15817233 Transmission Cooler Line OEM
LUBEGARD Lube Gard Automatic Transmission Flush ATF (6) Pack 95001
GM NEW OEM ALUMINUM REAR DRIVESHAFT 15152336 15833881 with Yoke and U-Joint
GM 4L60E Removable Bell Housing Style Transmission Case
10 Gallons of HQ Transmission Fluid (Repeat Flushing of Coolant Lines & Cond and Refill)
Fuel System Refresh: ( I bought the AC-Delco Fuel Pump already... work is pending)
Engine Head Replacement: (I Have Already Purchased All of These Components ad work is pending)
RockAuto LLC Re-Manufactured Aluminum Engine Head for 2002-2004 GM Atlas 4.2L Motor
New Genuine GM 24100263 Engine Camshaft Bolt
New Genuine GM 12565425 Bolt
Fel-Pro ES 72195 Cylinder Head Bolt Set
Fel-Pro Hs26214Pt Head Gasket Set
GM OEM 4.2L TRAILBLAZER OIL PAN
AC-Delco 15-11073 GM Original Equipment Engine Coolant Thermostat Housing
GMC O2 Oxygen Sensor SG1823 15894 234-4344 ES20113 21044 4 wire w/ OEM Plug
Dorman 674-777 Exhaust Manifold
Dorman 917-010 Variable Valve Timing Solenoid
Dorman Kit Exhaust Stud Front Full Size Truck Chevy GMC Sierra 03133
Dorman 03413B Exhaust Manifold Hardware Kit
Dorman 674-777 Exhaust Manifold Kit
Cloyes 9-0195S Timing Chain Set
Sealed Power 224-53582 Oil Pump Repair Kit
Fel-Pro Tcs 45051 Timing Cover Gasket Set
AC-Delco 15-40133 GM Original Equipment Engine Cooling Fan Clutch
Stant 14659 Thermostat And Housing - 190 Degrees Fahrenheit
AC-Delco D1843A GM Original Equipment Engine Oil Pressure Switch
AC-Delco 251-731 GM Original Equipment Water Pump
AC-Delco 251-2029 GM Original Equipment Water Pump Gasket
Cloyes S908 Timing Driven Gear
AC-Delco Re-Manufactured VVT Gear
Tools: (I Have Purchased These Over Time)
INGERSOLL-RAND 1210 1/2" PNEUMATIC RIGHT ANGLE RATCHET WRENCH 1210
CROSS BEAM FLOOR JACK LIFT ATTACHMENT
BRASS QUICK RELEASE AIR LINE COUPLER CONNECTOR SET FOR COMPRESSOR TOOLS 5PC SET Air Blow Gun w/ Rubber Tip, 3 Needle Tips & Medal Tip Heavy Duty
Mity-Vac 7300 Air Operated Pneumatic Oil Vacuum 2.3 Gal Capacity
COOLER LINE FITTING 4L60E SNAP IN TYPE 4L65E 4L70E TRANS OEM M30 M32 M70
Vacuum Transmission & Differential Suction Gun auto tool
AC-Delco Air Conditioner System Flush Canister Gun Kit R134 R12 R22 R410 R404
4 piece 1/4" to 3/8" 1/2 inch Drive Socket Adapter Reducer Air Impact Set NEW
Sunex Tools 3/8" Drive 12 Point 13 Piece Metric Deep Impact Socket Set – 3682
Sunex 3504 3/8" Dr. 4 Piece. Wobble Drive Extension Set
Transmission Tail Shaft End Cap Plug TH350 C4 200-4R 700R4 4L60E Power-glide
Miller SPX Tools 9318 Fuel Pump Lock Ring Wrench
KENT MOORE TOOLS J-21366 TORQUE CONVERTER HOLDING STRAP (56)
Kent-Moore Crankshaft Button Plug J-38416-2
Kent Moore J-38188 Cylinder Head Broken Bolt Extractor Set Kit Tools 2.5L Engine
KENT MOORE TOOL GE-48326 SEALANT TUBE DISPENSER TOOL
Kent Moore Camshaft Sprocket Holding Tool #J-44222 In-Line 6 Cylinder 4.2L GMT360
Kent Moore GMT360 Rear Main Seal Installer #J-44227 In-line 6 Cyl. Envoy Etc.
KENT MOORE TOOL J-41478 & J-41665 FRONT OIL SEAL INSTALLER / CRANKSHAFT
Kent Moore EN-46124 High Feature Engine Kit Extra Tools
KENT MOORE TOOL J-44219 COVER ALIGNMENT PINS
Kent Moore Crankshaft Balancer & Hub Remover Puller #J-44226 In-Line V6 GMT360
Kent Moore SPX GM - EN-48034 - Harmonic Balance Installer 4.2L Engine
KENT MOORE TOOL J-44222 IN-LINE ENGINE CS SPROCKET HOLDING TOOL GMT360
KENT MOORE TOOL J-44217 TIMING CHAIN RETENSION TOOL
Kent Moore J-44221 Camshaft Holding Tool
KENT MOORE EN-48464 LOWER TIMING GEAR RETAINER Aluminum Wedge
KENT MOORE TOOL J-41478 & J-41665 FRONT OIL SEAL INSTALL / CRANK BALANCER
450 Lb. Capacity Low Lift Transmission Jack. Remove & Replace Transmissions
GM 4.2L Camshaft Holding Tool
OTC 4554 1/2" Drive Torque Angle Gauge
AC-Delco ARM602-4 1/2-Inch Torque Measurement Adapter 4-147.6 ft-lbs
TEKTON 24335 1/2-Inch Drive Click Torque Wrench, 10-150-Foot/Pound
11 mm x 1.5 High Speed Steel Bottoming Tap
Kent Moore Differential Locknut Bolt Extraction Kit ST-1440
Wilmar W80498 Gm Fan Clutch Wrench
Assenmacher Specialty Tools 8032 32mm Fan Clutch Wrench
OTC 6667 Harmonic Damper Puller
Innovative Products of America 7886 14" Long 14mm Thread Top Dead Center Indicator
Here are three links specific to this Trailblazer set of repairs located on my Photobucket site presence. These are indexed on a long library list of other repairs and mechanical inventions that may be of interest to the members.
Fan Clutch Repair Tool (I have solved many mechanical problems with invention)
http://s557.photobucket.com/user/60dgrzbelow0/library/TRAILBLAZER_2002?sort=6&page=1
Chevrolet Trailblazer LS New OEM Engine Parts
http://s557.photobucket.com/user/60...NEREPAIR/TRAILBLAZERENGINEPARTS?sort=3&page=1
Chevrolet Trailblazer LS Specialty Engine Repair Tools
http://s557.photobucket.com/user/60...INEREPAIR/TRAILBLAZEREPAIRTOOLS?sort=3&page=1
The reason this job rounds off mathematically to the enormous expense of $85,000.00 is because I ruptured two discs at L-4-L-5 while doing this repair and lost the ability to walk from February of 2015 until my back operation ($50,000.00) in April of 2015. In between, my wife had to buy a new vehicle since I could no longer drive her to and from work (She bought 2013 Nissan Altima for $20,000.00 +)...and of course, I had to get transportation for my son so he would not lose his job and give him the freedom to drive to and from work, etc. because I could not get out of bed to finish the Trailblazer repair. So I was willing to spring for a a 2003 Chevrolet Silverado 1500 pickup truck (Well worth just $10,000.00), since I was certain I would need his help using that truck to work on the Trailblazer as soon I could ambulate. Whatever she spent besides, plus parts and tools for this epic repair rounds off to around $5,000.00.
So now that I have figured out how to navigate with cane, albeit a bit on the clumsy side and with a "cuirass" or armor-like back brace... I will soon be solving the problem of the need to pick up heavy metal parts, engine heads/headers, exhaust manifolds, etc. by modifying my two ton hydraulic engine lift with the addition of three bolt/chain on pulleys and a 1350 LB Electric Hoist with fine motor control to pre-position the long hydraulic arm and then use the electric hoist action to maneuver or wield weighty objects including the motor and transmission around inside the engine compartment and not risk further injuries. (See my Trailblazer Repair Tool for a look at the hoist and pulleys to be added)
This is very important to mention here... In his play "Hamlet" Shakespeare coins a perfect observation of what happens when we are faced with mounting problems:
"Troubles come... Not as Single Spies... But in Battalions!"
If you stroll around your neighborhood and knock on any body's door, invariably you will find some poor soul who has more troubles than you have. I've always been an optimistic person... so... unless something happens to me that makes me have to take a "Long Dirt Nap"... I will overcome my present difficulties and pound this Trailblazer back into shape... and speaking of pounding... I had the engine partially taken apart before I got hurt reaching through the driver's side wheel well to un-install the starter motor and my world went to sh*t. The next "pounding" will be the necessary duty of trying to loosen the 15 main engine head bolts by lightly hammering on each bolt IN THE ORIGINAL REVERSE TORQUE PATTERN! with a flat faced steel punch. I intend to be the first person in the western hemisphere to have successfully removed the Atlas 4.2L Engine Head ...without snapping of ANY of these @%!&*!!! Stretch-to-Yield Bolts. Of course from now on... I will be adding photos of every work segment if this is helpful to us all. If you see me getting into trouble with any bad approaches to the work... don't be shy... you can take a swing at my chin if you need to get my attention... and I am ever a good student and learner. :>)
