taller tire on 17" wheel 2 wd Trailblazer
No Tyme
100
Monroe County Michigan
I am looking at a set of 17 X 7" wide wheels for my trailblazer. I currently have 16" stock wheels and they are a mess. Mounted my current tires which are in need of replacement soon are 235 75R 16 and the tire height is 28".
I want to increase the height up to 30 to 31" and the width a bit also...
I am looking for tire size recommendations. Some of you out there know how tall and wide I can go without changing anything... No lift and no modifications in that area are planned.
I will appreciate any and all responses.
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
The maximum tire height that you can go to without a spacer and lift is 30.6". Of course that varies with individual vehicles.
No Tyme
100
Thank you DJ for your response. The wheels I found are OEM GM 5314's and I hope to snag them this week.
I will post a pic of my finished project soon....
Tiggerr
1,324
Perrysburg, OH
Idk what those wheels are from the part number....but our trucks have a unique bolt pattern 6x127mm or 6x5. Full size truck rims don't fit. Just FYI
No Tyme
100
Yep, that's the wheel. The guy who is selling the set I am looking at does state they come from a Trailblazer.
I am also looking at a set of 20" SS wheels but the seller can't give me a tread depth and wants $900 for the set. At that price I can't change the tire height without going over my budget. That is why the 17" are looking a bit better to me right now.
Even though I have a 2 wheel drive I want a bit more aggressive look to the TB so a bit taller tire than stock is what I want to come up with... I have 33" on my Silverado Crew with minor lift.
No Tyme
100
This guy with the 17"'s just doesn't answer or reply to emails or text messages... Crap!
Waiting for tire specs on 20" SS wheels and tires right now. May go that route.
Pittdawg
538
I would look to the aftermarket for a wheel with a little lower offset if you want bigger tires. Not a lot of visual difference going from stock 245-65-17 to 245-70-17 which is the maximum safe size when all stock. The lower offset will give you more room to squeeze a larger tire in there and not rub against the ball joint.
10,685
I got some 265/65/17s put on just over 2 years ago. They are 30.5" tall, and slightly wider. Close to the UBJ but they clear fine. Can feel the extra grip when cornering which I like. :biggrin:
No Tyme
100
Actually stock right now for me is 235 75 R16 which are suppose to be 29.69 in diameter.
The 245 70 R17 is only 30.5" in overall diameter.
That is not much more in height...
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
My 06 TB is running 265 75R16 on MB wheels, 30.6. They started on the 16" stock wheels. I have pics floating around someplace.
I like Rainier wheels.
Reactions: paul2005tb
Interesting that most on 265 75 16 call them 32s.
No Tyme
100
I think it may have something to do with the width of the rim, but I am not sure...
On my Silverado my 33" tires as the specs were given to me turned out to be closer to 31.7 once mounted and on the truck.
Maybe the overall dimension is when the tire is un-mounted... which does kinda make since.
I told the guy with the 17's that I am gonna take em'... Like the idea of OEM GM wheels over aftermarket myself.
4,656
Just food for thought, these platforms can take a hit in MPG's real easy when you start changing tires. If you are sweating a few bucks now, keep in mind you may be out alot more later.
If you go larger, look for a low rolling resistance tire if possible.
Reactions: No Tyme
It has more to do with people wanting to say they have bigger tires.
Reactions: djthumper
No Tyme
100
Oh, ya: I will get a P series tire and not an LT for sure. I got the biggest in P series for my Silverado...
Your not saying that some have to compensate with bigger tires because of something now are U???
LOL :hahano:
265/75/16 is almost 32 inches. That's what I have on my TB.
Either those numbers aren't right, or they marked the tires wrong lol.
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
maybe it is just the 70R16s that I have on there. I don't drive it that much anymore. I put those tires on awhile ago. I have to take it off-road again soon.
4,656
While searching for tires recently, I noticed the Michelin LTX MS/2 has the LRR rating with the LT sizes and not the P.. :confused: ...kinda odd.
I would never run P series on a truck or SUV myself.
No Tyme
100
Personally I find the extra weight of the 10 ply LT tires and the rough ride a needless and undesirable effect of bigger tires on trucks. I have Cooper Discover ATP’s 275 60 R20’s on my Silverado and they have a SL rating (4ply) and I am quite happy with them. They perform well on wet roads and in the snow. I don’t pull anything heave and if I do it’s dirt or stone on a single axel trailer. They also ride very good and are an exceptionally quite tire.
Most if not all LT tires are 8 ply or 10 ply and are a much heavier tire, have increased rolling resistance and degrade ride comfort, which will also decrease gas mileage… but if anyone lifts a truck they shouldn’t worry about gas mileage because they are going to lose.
The Cooper ATP's are a private brand sold by Discount Tire.
I'm planning on sticking with P tires on my Silverado too because of the extra weight/mpg loss for no real reason. It is only a 1/2 ton, no need for tires with a load rating way beyond what the truck is rated for. If I had a 3/4 or 1 ton then yeah I'd be on LT tires. The P rated tires are good for 2400 pounds each. No way I'm going to get 4800 pounds over the axle on a 1/2 ton truck.
Kinda sucks that the tires I really want only come in load range E (BFG T/A KO2). That's 3300 pounds per tire. Way overkill. Each tire is 8 pounds heavier than the Firestone AT P rated in the same size. Not sure how that translates into mpg loss.
*edit* now that I am reading more maybe I'm making a mountain out of a molehill. But one thing I know I'm not is the price haha.
Reactions: No Tyme
No Tyme
100
No, I don't think your making a mountain... I feel just as you do. I don't need that overkill on tire rating that I most likely will never need or use. Ride comfort is important to me but most of all low noise. Some of those bad boys hum down the road and I can hear them a half mile away... NOT for me!
Hey Sparky. Is your TB a 2 wheel drive or 4 wheel drive... Would like to see a pic of your wheels and tires...
I am heading out tomorrow to buy a set of 17" Hollander 5314's in chrome. Pretty good shape.
Hum and noise is tread pattern. You can have some near silent LT tires and some loud P tires.
It is 4WD. I'm just running stock 16" wheels on mine, but have 32" tires on it. Obviously have a lift and wheel spacers to fit them.
Reactions: No Tyme
No Tyme
100
Nice, I like the way it sets... I have the same color, emerald green I think it's called.
I am picking up the 17" Hollander wheels today and after I assure the fitment I will be heading for tires...
I am hoping I can fit 265 70 R 17" on my 2 wheel drive. The specs for Cooper Discoverer A/T3's are 31.43 in diameter. The last set I bought dropped close to an inch and a half once mounted... Maybe I'll get lucky.
paul2005tb
299
Massachusetts
Question: did you do any grinding on that control arm seat near the upper ball joint ?
10,685
Nope. The angle of the pic is a little low, but I was/am able to fit a finger tip between the tire and UBJ.
No Tyme
100
Wish I could figure out why I can't copy and paste into this forum... very frustrating especially when the page freezes and I have to retype everything...
FYI: running Internet Explorer 11...
Anyways got my 265 65 R 17's mounted... Look great and no issues what-so-ever.
Now on to the detail work...
Those wheels n tires look nice on there
Reactions: No Tyme
Kyle
36
To copy and paste, Click the light switch thing in the upper left corner. That will let you paste. Then click back on to get the other features back.. Nice looking wheels by the way!!
Reactions: No Tyme
No Tyme
100
FANTASTIC! Thank you for that info... This makes it so much easier for responding to this forum!
Pittdawg
538
Just a warning that I have some quite uneven wear in the middle of my 265-65-17s...they are tad too wide for the stock 7 inch wide wheels resulting in the uneven wear. When I need to replace them I'm going with 245-70-17s.
What PSI are you running? I have 265/75/16 and I have not noticed any uneven wear in 25k miles. The little taller sidewall may make a difference I suppose.
10,685
:undecided: I'll have to take a closer look at mine tomorrow. The few times I've been down around the tires, haven't noticed any uneven wear on 265/65/17s
No Tyme
100
Strange, Discount tire said they would fit but the specs for the Dueler H/L states rim width should be 7.5 to 9.5... Interesting.
I believe my rims are only 7". :confused:
Did you do a chalk test to get the proper PSI for wear?
10,685
Did a quick walk around mine before driving home, after 2+ years, the treadwear is even.
Pittdawg
538
That's the same specs for my tires and that's why I attribute the uneven wear to the tires being slightly too wide. Didn't have any problems with the stockers before these.
timmerk
