littleblazer
- Jul 6, 2014
- 9,265
I know for certain things it matters, I'm not educated enough on electronics to tell you yes though. Voltage on the other hand can be raised I believe.
For the cap mod, I found through searching that the capacitor should be 10uf 35v. I liked the idea of an axial lead capacitor, my RadioShack was fresh out of them but had a 22uf 35v cap. Does the uf value really matter in this use? As in would the 22uf capacitor work?
If not I picked up a standard leaded 10uf 35v cap just in case. Just think the axial cap would make for a cleaner install with the leads on the ends.
I am glad members take the time to do output comparison shots of projectors on HIDP. Helps to narrow down your choice and see what kind of output you are working with.
Heck I have to rewire some stuff because the previous guy ran 12/3 for two 20A circuits, sharing the neutral between them. Yeah that's safe
If they're opposite phases? That would actually work I think? We had to do that at the marina because other wise the whole dock would need to have been re wired and that's a shit ton of 10/3
Well it's all 30 amp plugs so maybe we have an issue after all.Not with 2 20amp breaker is that safe. 2 15amp breakers yes because one would trip before causing any damage to the neutral.
12 gauge although rated to max 20 amps. Is OK to run 27amps through. Unfortunately they don't have a 27amp fuse.lol. So that why you have to jump up to 10 gauge and your only good to pull 30amp. On that.
And of course distance is a negative drop off too.
Hey, the owner is the one who told the electrician to do it!I hope you got good insurance.
Anyone on here running these bulbs.
Sylvania 168/194/2825 LED Bulb, Contains 1 Bulb
I've been running them for some time now and I extremely happy.
Are you talking about this LED? When I was at Walmart picking up some oil the other day, I seen them there for $10 a piece. Up front its a lot of money, but when I think back to all of the money I spent on EBay LEDs that have burnt out within 6 months, I spent quite a bit. Seems like a quality LED.
Yes that's it. I've got them in my license plate and all the interior 194 replaced with them. It was expensive at first so I bought 2 at a time and none have gone out or flickered.
I tried a jdm astar 194 led that was a little brighter but it didn't last 3 weeks.
I saw a youtube video about a osram sylvaina 6700k 194 bulb I wanna try out.
I actually have those as my license plate lights. Had some cheap eBay ones that kept burning out. Had a gift card to Walmart and used it to buy a couple. They have held up nicely so far. Been about 3 months which is longer than the eBay ones lasted. Very bright also.
After my EBay ones failed, I also bought some JDM Astar from Amazon. The interior ones are holding up well, but its the damn 194 license plate lights that fail every 6 months.
Good to know. When I was looking at them, I was thinking how they would work out in my license plate lights. I might have to give them a try. Anything i better than replacing LEDs every 6 months.
I have to say that I think the LEDs are failing from opening/closing the rear hatch and vibrating the LEDs. I have the JDM Astar LEDs installed in the wife's license plate lights on the F150 and I have not had to replace one of those since installing almost a year ago.
^^^This, and I also think that when I wash my truck, the seal of the lens covers is not the greatest, so water may be getting inside and shorting them out. If these end up going out soon, will try to figure out a way to make a better gasket to seal them up a little better.
My seals were dry rotted and about the thickness of a couple sheets of paper which would allow water/moisture in. I bought some vinyl foam self-adhesive weather stripping and cut it to fit. The roll was much thicker than need, just had to cut the thickness in half. I could not run one continuous strip, so I just cut four pieces to fit.
I always thought it was rod down. Maybe swap bulbs and see if it follows it then compare the rod? Maybe it's bent.Bit frustrated with the H1 and projectors. I have a shadow in the driver beam. It has to be from the lil rod thing, but I tried putting it to side like the headlights seem to indicate should be and the passenger is, but dr has shadow. Rotate it to rod down and still a shadow. Does not seem to want to fit any other way due to slots in the bulb mount. Which way should the lil rod be facing? Never had H1 bulbs before so it is F'ing with my mod addicition to not have these dialed in yet
