- Oct 14, 2012
- 34
TB is a 2005 LT 4x4 with 125k miles. Noticed a creeking noise as if something is stretching while I press on the brake pedal. Seems to start when you get some pressure back from the pedal. I don't think the brake lines have ever been bled (owned it since 60k miles) so I was thinking of doing that soon. Anything else I should look at that could be causing the creeking sound?
Or is it simply time to tear the front breaks apart and clean/derust/lube them up?
