- May 16, 2015
- 82
I am having some weird issues starting my trailblazer in the morning. It seems to act up when sitting longer. Almost all the time it starts up with a hesitation, sometimes it knocks really bad, sometimes the starter grinds after the hesitation. I got one video so far of the starter grind, but I'll keep recording it in the mornings so catch the knocking.
All coil packs replaced two years ago, spark plugs replaced 1 year ago. I just pulled all the plugs and everything was dry, no oil, plugs tips look white. Cleaned throttle body(battery unplugged for 20mins), mass, map sensor last week. CPAS was replaced 3 years ago. Just put castrol edge 5w30 in it. Starter is 3 years old. I don't think its a failing starter tho.
Once it's started its fine, still has lots of power.
I guess I should mention, I do have a pcm4less tune (back when they where pcm4less, not pcmofnc) I have it set to premium fuel, and thats what I have always used. There is currently a bottle of lucas fuel injector cleaner in the gas tank to see if that helps any.
