NEED HELP stacking on front struts
EarlsTB
57
TN
I have searched and searched and can't get a definite answer. I have the rc lift and ordered the smaxx spacers. Can I stack them in the front??? I am looking to do it Friday and would like to know if its possible without future problems
Not safely
EarlsTB
57
TN
Thanks guys! I will just install the rc lift this weekend
kickass audio
955
I don't plan to lift my truck aside from what i did with using the tahoe springs in the back but what if he put the spacer at the top and another spacer at the bottom of the spring? Is that still dangerous or can they only be mounted in one place?
hockeyman
726
In my opinion, it's should not be done because -as mentioned, safety reasons.
Once a single lift kit isn't enough for you, you should then start looking into a whole "Body Lift Kit" where you modify the complete suspension. OEM parts (lower/upper control arms, tie rods, etc) can only stretch so far before they begin to fail and compromise safe road traveling. Stacking lift kits will make the OEM parts begin to reach-out too far and things can and will begin to break. And hopefully, not while you're traveling at a speed that can kill you or anyone else...
Moderators: If I'm wrong, then go ahead and delete or edit my post here.
Reactions: kickass audio
EarlsTB
57
TN
I was trying to avoid the body lift cause I have never done one but that might be my next purchase after ss wheels a spacers. Any one want to buy a pr of 1.5" coil spacers? My loss your gain
I ran top and bottom spacer with rear coils. No issues. The front is the problem area
06_4.2_4x4_ls
