I have been having a problem with a rough idle and after trying various repairs, have been unable to resolve the issue. I have thoroughly cleaned the throttle body, replaced the MAP sensor, replaced the coolant temperature sensor, replaced belt tensioner, replaced spark plugs, replaced motor mounts, replaced battery, replaced air filter, and performed a smoke test to check for vacuum leaks. I did get a po420 which pointed to the catalytic converter which I checked and cleared the code after failing to find any issue with the converter. I recorded live data with my scanner and found issues with the short term fuel trim and ignition timing information. If anyone has experience in interpreting scan data and determining possible solutions for data outside normal parameters, please remind the video link below and let me know what you think. Do I have a vacuum problem or more serious internal engine problem?
2004 Trailblazer LS EXT 4.2 I6
