- Jan 13, 2012
- 31,981
Earlier today as I was backing out of a parking spot I heard crunching/rattling coming from possibly the front right. After I starting to go forward I heard a metal on metal screeching noise, similar to the the noise from the brake dust shields (been there and done that). The crunch/rattle/metal noises only happen at low speeds (20 mph or lower) and seem to only happen when turning (slight turn or full turn). I am unable to get the noises to repeat on command, they seem to happen randomly and not every time. There is no noise going straight or at speeds greater then 20 mph.
After much searching it seems like it could be a failed CV Joint. Does this sound like the correct path or is there another area to look into?
-90,000 miles.
-All fluids are current and in good condition.
-Brake pads and rotors are new.
-The CV Boots are not torn.
-There is no obvious signs of leaking.
-90,000 miles.
