Voltage is normal for an 07. Most likely a tstat at issue...Mounce said:Got any codes? Might be time for a thermostat or ECT sensor.
-voltage is low too. Ever worked on the cluster? Needles might be out of spec.
Don't know about 07, but my 08 has the ECT sensor at the back of the engine.. nowhere near the tstat. I did not change it when I did my tstat.dmanns67 said:You need an ELM327 and the TorquePro app so you can read live data. Those gauges are a waste of time. The coolant temp never runs at 210° to begin with. Usually around 194° with a functioning tstat.
You do not need a code to change the tstat. Using the ELM and app is how I figured out my tstat was getting stuck open. Never seeing temps above 183°.
98% of the time, the issue is with the tstat, but it is highly recommended to change out the ECT sensor with the tstat. Sensor is right above the tstat. You can get both parts off of rockauto.com for around $20 each.
06-09 ECT sensor was moved to the passenger side of the engine near the firewall, huge PITA to change. 02-05 the ECT sensor is near the tstat on the driver's side of the engine. I am on tapatalk so I cannot see the OPs vehicle information.coolasice said:Don't know about 07, but my 08 has the ECT sensor at the back of the engine.. nowhere near the tstat. I did not change it when I did my tstat.
Hmm.. So that's where it is... I bought an ECT sensor when the thermostat stuck open last year on my 2006 TB, and I saw posts that the sensor was beside the thermostat. I never replaced the sensor since replacing the thermostat fixed my problem, and the thermostat took longer than it should have since GM did a good job hiding it. You have to remove the alternator to get to it. I did have the P0128 code, though.dmanns67 said:06-09 ECT sensor was moved to the passenger side of the engine near the firewall, huge PITA to change. 02-05 the ECT sensor is near the tstat on the driver's side of the engine. I am on tapatalk so I cannot see the OPs vehicle information.
I did the same thing although I never had the code thrown for it. Never did the ECT sensor... had no reason to.Kurb said:Hmm.. So that's where it is... I bought an ECT sensor when the thermostat stuck open last year on my 2006 TB, and I saw posts that the sensor was beside the thermostat. I never replaced the sensor since replacing the thermostat fixed my problem, and the thermostat took longer than it should have since GM did a good job hiding it. You have to remove the alternator to get to it. I did have the P0128 code, though.
You are correct sir. In the end, by ignoring a failing tstat you could end up clogging your cat due to the engine burning more fuel and trying to run hotter since the optimal temperature is not being seen at the ECT sensor.littleblazer said:After they replaced mine (160ish) it currently runs 196-201 at 20 degrees and 70mph. You're going to burn a bit more fuel running colder too I believe.
I would definitely change it out. I noticed an improvement when I changed mine.eray2371 said:Just finished my 250mi trip home....kept an eye on the torque app and it's running about 173 degrees at highway speeds. So I'd say there's no urgency in putting the t-stat on. Thanks for all the input gentlemen!
Yep! This is what happened to mine. If had only only known at the time that running a little cool would cost me that much money and work...Denali n DOO said:I wouldn't be happy with 173, I'd change it. Think it can mess up the cat too...
SB, do a scan and make sure. Sure sounds like you have yours stuck open, and need to replace it asap.SnowBlazer said:I just noticed that my T Stat needle only gets to about 1/4 of the way up.
I'll grab some pictures here in a bit.
Will do...she's parked now, so I'll probably run by AutoZone later and borrow their scanner. Only thing is, is that she's my DD so I'll have to drive it until I can get that part.Robbabob said:SB, do a scan and make sure. Sure sounds like you have yours stuck open, and need to replace it asap.
How have you not bought a code reader yet Buy an ELM327 and download the torque app. For $25 you can read and clear codes. You can also see live data which would show you what your coolant temp is actually is.SnowBlazer said:Will do...she's parked now, so I'll probably run by AutoZone later and borrow their scanner. Only thing is, is that she's my DD so I'll have to drive it until I can get that part.
And it looks like TapaTalk doesn't want to upload my photos
I haven't found where I can clear codes, but I certainly can read them. Probably just my bad learning curve. I'll have to leave my gas cap off so I can throw a code.dmanns67 said:For $25 you can read and clear codes.
I Have an iPhone so would EngineLink work? Also, are the blue ones like these any good? http://pages.ebay.com/link/?nav=item.view&alt=web&id=231076061631Robbabob said:SB needs to get with the program on the ELM, though, for sure.
