So I'm removing my transmission so I can replace the main seal and main cover gasket. Any tips for removing trans? Never pulled the transmission out of a trailblazer before
I've done this 6 times now on the three different 4.2L GMT360's, but the same will apply for your 5.3L minus the starter removal, it's a pretty straight forward task. Sounds like you've done this before on other vehicles, so no offense if I state obvious things with this task.
Here's a few things I make sure of when doing this:
-Leave the top two bolts in partially before you drop it, to make sure all transmission and fuel lines are clear, wiring harnesses are clear, and you've got the transmission steadily balanced on the jack. Do the same thing with reassembly, do the top bolts first right after you position the transmission in place and get it seated on a protruding guide that's on the passenger side. It makes sure the trans is in line with the rear of the engine.
Blue Loctite is your friend, add to all bolts on the drive shaft straps, flex plate, and torque converter. I also used a
paint marker on all the torque converter bolts as well as the flex plate to check for any walking themselves out, had it happen before with the torque converter (
forgot to put Loctite on one bolt before).
-It also wouldn't hurt to add some RTV sealant below the rear main seal area,to further reduce the chance of any oil leaking from this area
-Clean any gunky/burned up oil at the rear of the engine real good with some Gunk Engine De-greaser, stuff works wonders.
I marked the areas that needed cleaning.
-Putting a
latex glove with a bunch of electrical tape around the end of the transmission tail shaft will hopefully keep any transmission fluid from spilling all over the floor.
-When reassembling, make sure the torque converter is
fully seated as far back as it can go by turning it until it slides back, then rotating it around again until it slides back once more.
If it's not seated properly, it'll break this plastic piece on the pump shaft (can't recall what it was at the moment). You'll know if it broke if it's not even going anywhere in reverse out of the garage.
----Interesting fact:----
Why did GM made this part plastic? As a fail-safe, to save the rest of the transmission pump from an issue that would otherwise cause catastrophic failure to the pump as a whole.
I have a pictures from my bud's wife's EXT pump that we replaced below:
Broken plastic part:
You can see how the plastic part of the pump here keeps all those small pieces in check and in a certain position (left) vs. the right, where half of it is all cock-eyed:
Healthy unbroken plastic:
-When reassembling, bolt the transmission mount on the tail shaft
before you put the cross-member in, makes everything much easier.
-When reassembling,
make sure the
transmission dipstick seal is in place, as well as make sure you fully seated the dipstick in place
before you jack the transmission up fully and put the cross-member in. It's a PITA to put it in place once everything is bolted up already. It's doable, but it's difficult because of lack of space and not being able to see what you're doing. If the seal isn't there or if the dipstick isn't in all the way it'll spew transmission fluid all over the exhaust pipe every time you take a sharp left turn (
speaking from experience; dip stick wasn't in all the way the first transmission rebuild install I did)
