This is Very Important:
I've been thinking about something that
@littleblazer mentioned above concerning a circumstance where a Flex-Plate Failed under such circumstances involving it detonating with such violence as to damned near cut a vehicle half in two. Given the dreadful condition of how
@Capote 's Flex-Plate turned out to be and to
@littleblazer 's observation... it seems terribly important to take this idea under advisement before considering to Start Up The Engine after the Torque Converter Bolts, the Transmission and the Torque Converter have all been removed.
There would be a very real danger in starting and running the engine at all; let alone suddenly raising and lowering the RPM while the Flex-Plate is only being held just by the (8) Bolts in the centre where the cracked areas won't be easy to see or detect... just under the Stainless Steel Thrust Washer under the (8) Bolts. If something untoward were to occur... there is no telling whether or not the Plate itself might break loose and Fly off of the Tail of the Crankshaft and wreak havoc towards anyone standing near or laying under the vehicle.
I remembered this Youtube Video was being done to investigate the strange "Bell Ringing" sound which appears to be the familiar, redoubtable sound that a Broken Flex-Plate can make if cracked in one or more of the 'Kidney Bean' Cut-Outs leading back to its centre. And so of course...this would be the very last place you would want to be standing near to... or lying under... should the Flex-Plate suddenly come apart without the Torque Converter Bolts and Torque Converter present to restrain it in place and not fly around in that vacant space at high speed like some Deadly Toothed Demon Frisbee:
