I'm looking to replace rusted out rear backing plates (dust shields). Anyways, to do so the rear axles must be removed. I hear the 06+ models with rear ABS are more difficult to remove the axles. Are the steps the same as earlier models, or do I have to mess with a "reluctar ring?" Where exactly is this ring at and can I pull the axle shaft with it still intact? Just looking at what I should expect before digging into this. May replace rear axle seals as well as they are starting to weep a little.
