Pro Comp 7005
I think they would sit about 2 inches wider than stock depending on which factory wheels you had. Should not stick out too far.
So they are 20x8.5 with a +31 offset.
Should only be out about an inch wider.
That is my guessimate...The info is there for someone that wants to actually calculate it. I found the 20 inch specs on another forum, but actual calculations for where the wheels will sit is something I never bother with. If I like the wheels, I buy em and bolt them on.
MissCrutcher
