Part Number for 2007 I6 Thermostat
TB_n00b
121
Queens, NY
Hi all,
First post for me here after discovering the mass exodus at trailvoy.
Posted there but am doubtful the info will be forthcoming.
Looking for the correct part number for my thermostat replacement.
RockAuto gives me 2 options:
ACDELCO Part # 1510715 {#12579972, 12605785, 1510590}
OUTLET,WAT INCLS OUTLET,CONNECTOR,SEAL
and
ACDELCO Part # 1511006
HOUSING,ENG COOL THERM THERMOSTAT, SEAL, TO WATER PUMP
Thanks!
willn513
I have an extra thermostat for my 2002 I6 in my basement right now. PM me if you want it and ill give it to you for the cost of shipping. It wouldn't be until after xmas though....
TB_n00b
121
Queens, NY
AbsoluteZero said:
ACDELCO Part # 1511006 is what worked in my 03 Envoy
And does that part have the angle to it? the photo on rockauto for that part shows a straight pipe from the engine mount side to the hose side.
AbsoluteZero
211
It was an exact fit including the curve. Often what's confusing is the thermostat and housing are one unit. Most stock photos don't show the curve.
This link is from Amazon's site showing vehicles it fits:
Amazon.com: ACDelco 15-11006 Thermostat Housing: Automotive
Mark20
1,630
Yeah replacing the sending unit is prudent since your in the neighborhood esspecially if you pulled the alternator. If you get a new sender, take the teflon tape off and put new on but only 2 - 2.5 wraps. Mine came with 3 or 4 and that is too much. It balled up as I was tightening it and leaked. If you can find an 18mm sensor socket (similar to an O2 socket with a slit for the sensor wire) you will make replacing that a lot easier. Failing that I ended up using a crow's foot wrench on my socket driver. Also a stubby flex head ratcheting wrench is good for the lower alternator bolt. 15mm IIRC, same size as the upper bolts.
Firebaugh86
