- Aug 7, 2013
- 76
So, I just changed my valve cover gaskets on my 2002 Bravada. I am afraid that I damaged the throttle body while cleaning it. As soon as I started it the SEC and "Reduced Engine Power" lights came one. The code is a P1120: Throttle Position Sensor Out of Range. When I was cleaning the butterfly I was opening and closing it by hand a lot. Could it have "jumped a cog" or something while doing that? If so, is there any way to fix it?
I was using carb cleaner as well. But being carb cleaner, I assumed it would not harm it.
It idles fine. And it runs fine when driving, except for a lack of power which I assume is being caused by the PCM due to the error code.
