NEED HELP P0496 06 LS 4WD 4.2
DirtinLa
20
Gonzales La
Y'all were such a help with my p2440 code (simple fix bad relay #55)
that I am hoping for the same help now on P0496
I have already changed out the canister purge valve underneath the truck.
I put voltage to it and the valve wasn't doing anything
autozone part number 25950499
http://www.autozone.com/engine-mana...-purge-valve/475639_231041_5759?checkfit=true
it's my understanding there is another solenoid/valve on the right hand side of the motor
that folks have been changing as well.
autozone part number PV443
http://www.autozone.com/engine-mana...ster-purge-valve/180004_0_12209?checkfit=true
May I please get assistance removing this code?
AtlWrk
674
The valve you linked to is the evap "vent" valve. These get confused a lot (even Autozone has the part name incorrect) with the actual purge valve:
http://www.autozone.com/engine-mana...ster-purge-valve/475635_0/?_requestid=1251757
The purge valve is the one on the driver's side of the engine, below the intake manifold. The P0496 indicates that yours is stuck open or leaking. Fortunately there's not a whole of diagnosing to do for this DTC, just replace the solenoid.
DirtinLa
20
Gonzales La
changed it out ... it was bad
NOW another damn CODE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
P1516
I have had never ending codes
Thanx for helping with this one... now on to the next LOL
-=Fred=-
ready67
