Ok after fixing the Trailblazer with a pretty good amount of parts and the dealer replacing the fuel tank under warranty, driving this morning the SES light popped up and I took it over to Auto Zone to get scanned. I thought my P0440 code days where over, go figure I put LEDS in my dash and the SES is jealous since its not the main bitch ass light anymore ha ha
So I checked the lines at the throttle body, its tight
I checked the purge valve on the front the engine that was replaced recently, all lines are tight and not loose
I check the tank that was replaced by the dealer and everything looks fine, no leaks and hoses are tight to connections
What gives? The Trailblazer is running the smoothest since I got it and the gas seems to be lasting longer than before....Any ideas? I don't want to start throwing money at parts that may not need to be replaced. It also should be noted gas is on its last 1/4 before fill up.
