I have researched it on both this forum and Trailvoy and this what seemed to indicate would be the Gen 2 sensor for my 2003 Trailblazer
https://www.amazon.com/gp/product/B000NW4PJC/?tag=gmtnation-20
Good thing I looked at my current upstream (manifold) sensor, because the above part would have not fit and does not have the correct fittings
So which is the Gen 2?
Here's the Ac Delco OEM center (downstream)
https://www.amazon.com/ACDelco-213-1574-Original-Equipment-Heated/dp/B000C9GNLE/ref=sr_1_1?s=automotive&ie=UTF8&qid=1471030202&vehicle=2003-47-489-96--9-6-8-7416--1-1-145-177-1-0&sr=1-1&ymm=2003:chevrolet:trailblazer&refinements=p_n_feature_keywords_browse-bin:3941084011
Heres the Ac Delco manifold (Upstream) with the correct fittings
https://www.amazon.com/ACDelco-213-1551-Original-Equipment-Heated/dp/B000C9HWQE/ref=sr_1_2?s=automotive&ie=UTF8&qid=1471030289&vehicle=2003-47-489-96--9-6-8-7416--1-1-145-177-1-0&sr=1-2&ymm=2003:chevrolet:trailblazer&refinements=p_n_feature_keywords_browse-bin:3941084011
Here is the Ac Delco professional model (downstream) which has thicker shielding than the OEM and same price https://www.amazon.com/ACDelco-213-2881-Professional-Heated-Oxygen/dp/B0010GIUTQ/ref=sr_1_3?s=automotive&ie=UTF8&qid=1471030289&vehicle=2003-47-489-96--9-6-8-7416--1-1-145-177-1-0&sr=1-3&ymm=2003:chevrolet:trailblazer&refinements=p_n_feature_keywords_browse-bin:3941084011
Here is the Ac Delco professional model (upstream) which again has thicker shielding than OEM but is way more expensive than OEM
https://www.amazon.com/ACDelco-213-2915-Professional-Heated-Oxygen/dp/B000EQP94C/ref=sr_1_4?s=automotive&ie=UTF8&qid=1471030289&vehicle=2003-47-489-96--9-6-8-7416--1-1-145-177-1-0&sr=1-4&ymm=2003:chevrolet:trailblazer&refinements=p_n_feature_keywords_browse-bin:3941084011
So I assume the Ac Delco Pro is the Gen 2? Also Denso makes the Oxygen sensors for Chevy and rebadged as Ac Delco...So why not use Denso?
Denso (downstream) cheaper https://www.amazon.com/dp/B00199BX3O/?tag=gmtnation-20
Denso (Upstream) only problem I see its says Universal cant see the fittings? https://www.amazon.com/dp/B000C5WCUE/?tag=gmtnation-20
Denso (Upstream) Air and Fuel Ratio Sensor https://www.amazon.com/dp/B000C5SG4A/?tag=gmtnation-20
