Alright, today the TB started acting up. I haven't driven it yet to validate anything but I figured I'd go ahead and throw it out here to go ahead and get other opinions.
It was driven about 10 miles then when put in park the oil pressure went to zero (I know the gauge is a fabricated number) and the check gauges light came on because of it. I left work and got to it about 30 minutes after the incident.
Oil full, no codes, nothing appeared to be leaking. Started it a few times and it acted fine so I left and it got driven home. Going down the driveway (decent decline) it repeated, no pressure and check gauges light.
Couple hours later it was driven about 4 miles, issue repeated again when put in Park. Drove about 4 miles back home and coming down the driveway it happened again but then cycled back and forth, pressure coming and going. I'm told it runs and sounds fine while this all is happening.
I'm thinking pressure switch and that's why I let it get driven a couple more times. Doubt oil pump because it shouldn't come and go like that, if it went I figured it would stay gone. Filter is suspect of course but it's ACDelco so surely not. About 1500-2000 miles since oil was changed. Around 125,000 miles on the clock and of course has the 4.2.
Any other ideas? I'm thinking go ahead and get a pressure switch and possibly change the oil filter. About to go drive it and see if it'll act up for me.
