Nylon fuel line repair?
eightshot627
79
I found a pin hole in the nylon fuel supply in that runs across the top of the fuel tank. It is in a straight section that a rock got wedged in an rubbed through.
Cut at the hole then use a barb to splice it back together?
Any other suggestions?
Thanks!
Walt
Yeah, Dorman are good for oddball repair stuff like this.
eightshot627
79
Couldn't find any of the quick kind in stock but I did find the barbed splice. I drew a line with a silver sharpie and cut the section out. After watching a couple of you tube videos with hair dryers, heat guns and lighters I used the tube clamp from my tubing flare tube kit to hold the tube and spit on the slice and shoved it in with a nut driver. It went all the way to the collar. Then i used the tubing holder from my doulbe flare kit to hold the other end of the tube lining up the silver sharpie and shoved it on to the collar too. Also I hose clamped it for good measure. I presure tested it by hooking the lines up while the tank was still on the ground. No leaks. Back up and running.
Thanks for the replies!
Walt
chirobo1
