Need service manuals? Get them here!
Wooluf1952
2,663
Milwaukee, Wisconsin
Mooseman, in your signature where it says " Need service manuals? Get them Here! " , it doesn't connect to any thing for me. I've tried Google Chrome and IE, and I get nothing.
Do I have a setting wrong? Am I missing something? Or is it not linked?
The links in the initial post do work.
What are you talking about? It works fine!
I fixed it :biggrin:. Must have been screwed up during the software change last fall or when I changed my signature and links
Reactions: Wooluf1952
paul2005tb
299
Massachusetts
Many thanks Mooseman. As a nooblet I am eager to learn all I can.
Question: I have just downloaded the 2002-2005 service manual, would there ever be a reason why I might want the 2006/07/08 documents ?
Sure, if you own a 2006/07/08 :biggrin:
05TB90TROOPER
37
My pleasure. It was someone at TV that shared them and I just made it easier by hosting them since file sharing sites are crap. And since I don't really use my site for anything (really, there's nothing there so don't even bother), figured it could be put to good use. They seem to be some sort of factory manuals or third party but they're legit. Only thing I could see in there was "Courtesy of General Motors". Thanks GM!
Nothing to register. You should just get a prompt for the login and password. If any problems, just send me a PM.
PS: I don't know why, the links at the OS don't work anymore :tongue:[/
I downloaded the 02-05 service manual and have a question. Is the 2004 cooling system the same as 2005 ?? I have replaced the water pump ( airtex ) fan clutch ( hayden ) thermostat and ECT sensor ( AC Delco ) new belt and cleaned the throttle body and still have the P0480 code come up at start up of vehicle. I'm going to test wires on Easter Sunday but want to confirm that the test procedure is the same
Yes, they are the same. Check the fan fuse and relay, which you can swap with the headlight relay to test. If still having issues, please start a new thread in the tech section.
05TB90TROOPER
37
I replaced relay with new relay also, did not check fuse
I need to get thru inspection here in NJ
hawkeye405
109
Chicago
Hi Mooseman, is there a schematic showing all the colors of the wires going to the 3 connectors of my PCM? I thing a service tech broke off the lt blue/white wire from the 3rd connector.
I'm on my phone at work right now so I can't check at the moment. Send me a PM to remind me when I get home tonight.
7,727
I've got a feeling this one is somewhere amongst the others... but after searching each listing, I could not locate it specifically. And since this is for the Oldest of The Trailblazers... I thought it would be worth grabbing a DL of it before it disappears completely:
432 Page PDF ... Original Owner's Manual 2002 Trailblazer:
http://www.vadengmpp.com/owners-manual/chevrolet/2002-Chevrolet-TrailBlazer.pdf
loondog33
84
So to bother you but I can't seem to get the link to work. I put in my user id and password but it just resets the fields? I disengaged the block up block. Any ideas?
Edit: Sorry, I should have read where you wrote in large red text the username and password. :dunce:
Much appreciated brother!
matermark
59
Niagara Falls NY
Thanks so much for all your hard work! Do you have anything 04-05 Envoy ***XUV*** specific? I found the Getting to Know...
XUV quick manual but only viewable page by page no .PDF, and the 04 owners manual is mercilessly the same format, over 460 pages I think!
What is posted is all I have. Our resident XUV SME @TollKeeper might have something.
8,053
I actually dont.... :stars:
My knowledge is just kinda buried in my head, or I simply dont know. I know some tricks of when -x- happens, follow this procedure. But my XUV has actually been so reliable, except for the electronic latches, that I really dont even think about it anymore. I used it over christmas to get my sons new PowerWheels home, and I used it again last night to get my new office chair home. Both times the electronic latchs stuck open. Used a dead blow hammer that I keep in my drivers rear door at all times just for this, and went about my day. Other than when I use it, it doesnt really exist, if you know what I mean.
Kinda sad really, getting so close to 200k on it now, and I know this will be the last year (I think) that I will likely be driving her. I had plans for it, but age (my personal age) is dictating I likely go in a different direction. I still have the GT5 differentials sitting in my garage, sitting right next to the single bank turbo, but I just dont think its going to happen.. Mainly cause this engine just refuses to die!
8,053
I found this factory XUV owners manual, not sure how much help its going to be..
***Link Removed, Dead Link***
Added the link to that manual in the first post. :2thumbsup:
8,053
SME?
EDIT: Nevermind, figured it out.. LOL. Im getting to old for all these abbreviations, and MEMES
What is the SME stand for?
The abbreviation SME means "Subject Matter Expert"
8,053
There is a "SME" that I know of for the XUV models.. Hes not on this forum thou, hes over on the facebook forum. Anthony Cath Cindri (i think was his name).. But I have to warn you, he is one of the biggest A-holes that I know of. No matter the truth, he is always right, and how dare you question his opinion. AND HE IS ALWAYS TALKING IN CAPS TO EMPHASIZE HIS POINT!!!!!. If you dont respond to him in what he feels in a reasonable amount of time, he just uses Facebook Messenger to call you, no matter the time. I just had to call him out, and then block/ignore him, as have quite a few other members. You have been warned. LOL
We also have the member @Billdaman1 that was actually part of the original engineers that designed it and owns one.
Wherever you downloaded it to. Default is usually the Downloaded Files folder.
jvest
