Need an ABS sensor clip
deagle12
33
TX
Replacing my upper control arms... the damn clip for the ABS sensor broke off.
The part number for the entire ABS sensor is 19303071
This is about the cheapest thing I can find... I only need the little grey clip.
https://www.amazon.com/dp/B06XK99KTX/?tag=gmtnation-20
Anyone know if it is possible to find that little clip by itself? For now I'll just use zip ties but that doesn't seem like an ideal long term solution.
I'd probable just zip tie it to the arm. If picky on the esthetics, I'd get a couple from a pick-a-part.
deagle12
33
TX
Ok now I've got a bigger problem. The new control arm will not go down on the new ball joint. The old one fit fine but this new one isn't seating down.
I've tried opening the pinch bolt with a flat head+mallet then mallet the control arm down but it's not budging. It almost seems like the boot on the new ball joint is too thick to compress any more.
Any tips or tricks?
06_4.2_4x4_ls
