While replacing a coil pack this weekend I found some light brown goop all through the inside of the intake resonator. After cleaning my throttle body I used TB cleaner to spray out the resonator then let it air dry in the sun for a few hours before putting it all back together. What is this stuff?
I'm getting a P1174 code which I think is for a plugged injector. I will be replacing the spark plugs soon and currently running a FI cleaner through this tank of fuel. Also I will be installing a new T-stat and sensor since the temp won't go over 175* Not sure if any of this is related. Thanks!
