Lowered/ HD Bilstein shocks
kevin carvajal
42
Fairview
What's up guys? Quick question, I have a 06 TB ext ls 4wd and was wondering has anyone lowered their truck with HD Bilstein shocks? Any pros and cons? Any input would be awesome
Thanks in advance!!!
Wooluf1952
2,663
Milwaukee, Wisconsin
I may be miss reading, but, shock don't lower a truck. You need to get shorter springs. SS springs will lower about an inch, IIRC.
10,685
Depending on how much lower you go with the springs, an issue you can run into, is when you lift the vehicle so the tires leave the ground, the rear springs can fall out, if you don't have shorter shocks to go with them. :twocents:
Reactions: FearlessAZ
06_4.2_4x4_ls
