lost factory brake control function 07 silverado
05TB90TROOPER
37
have a customers truck and lost factory brake control and all 7 pin functions on trailer plug, all fuses and relays good have power on 12 line to factory controller and 12v charge line but not at plug :confused:
Mounce
13,667
Tuscaloosa, AL
Tried tracing the wires to see if they've been severed?
Have you checked the ground for the plug? Might be loose or need cleaned.
05TB90TROOPER
37
harness is intact and sealed front to back, used a jumper harness from battery ground to rear, still no voltage
05TB90TROOPER
37
disconnected factory brake control now all except brake controller ( of course ) works. installing tekonsha brake controller
05TB90TROOPER
37
all working now with tekonsha primus iq installed, this truck was used for plowing snow and salt spreader. Think maybe salt got inside factory contoller on frame
jonnnnyj
