1. We are working on the forum's attachment system. Attachments and avatars will be intermittently affected over the next 24 hours.
    Dismiss Notice
Looking for discontinued part
Discussion in 'FAQ' started by Joe Rooney, Jun 9, 2017.
  1. Joe Rooney
    Joe Rooney New Member
    4
    0
    I have a 2002 GMC Envoy and I am trying to track down where I might find an Electronic Blower Motor Control Module/Resistor. The OEM part # for GM is 52494707 and the AC Delco equivalent is 15-80186. Anyone have any ideas on where I could find this part?
  2. Sparky
    Sparky Moderator
    10,499
    5,320
    Automatic or manual climate control?
  3. Joe Rooney
    4
    0
    Automatic
  4. Sparky
    Sparky Moderator
    10,499
    5,320
    xavierny25 likes this.
  5. Joe Rooney
    4
    0
    I saw that one. Don't see the pigtail out to the blower motor though. Probably requires wiring which I suck at.
  6. Mooseman
    Mooseman Moderator
    10,301
    4,811
    It does require that you rewire the existing connector. It's pretty straightforward with instructions. It's an improved version.
  7. Joe Rooney
    4
    0
    Does it come with the necessary connectors or would I need to grab some elsewhere?
  8. Mooseman
    Mooseman Moderator
    10,301
    4,811
    It should come with everything except maybe the butt connectors. I would solder instead especially for the high current.
    Capote and Tiggerr like this.
  9. Tiggerr
    Tiggerr Gold Supporter
    1,187
    436
    There's only 3 connections it's pretty simple. I just did mine not long ago.
    If your squeamish about soldering... this is a pretty cool alternative I've used with good success when in the road and need to make a repair...
    They have a ring of solder in them...just hit them with a little butane torch and voila...the solder melts and the tube shrinks up...
    You get the good solder connection, with the ease of a butt connector...
    I usually put another shrink tubing over them for good measure....
    https://www.amazon.com/gp/aw/d/B01E...36_SY340_QL65&keywords=fotga+soldering+sleeve
    Capote and xavierny25 like this.
Share This Page
