1. We are working on the forum's attachment system. Attachments and avatars will be intermittently affected over the next 24 hours.
    Dismiss Notice
Leafspring on rear axle
Discussion in 'Towing' started by Mirror, Jun 16, 2017.
  1. Mirror
    Mirror Well-Known Member
    286
    21
    Not sure where to post this. I want to build a trailer using the rear axle from a tb. I have a trailer frame that has a 5x127 pattern axle on leaf springs. How do i go about swapping the axle out? (I tried finding hub adapters instrad by no one makes that conversion)
  2. Tiggerr
    Tiggerr Gold Supporter
    1,187
    436
    You'd have to use TB wheels....
    Then make spring mounts yourself I'd imagine, and weld them up..
    Idk why you'd want the extra weight of that axle on your trailer though...
  3. Mirror
    286
    21
    Cause i have a set of tb wheels to use on it.
    The trailer has a chevy axel already. The frame is from a ¾ ton. The trailer is being used for offroad camping.
  4. Sparky
    Sparky Moderator
    10,499
    5,320
    How do the leaf springs attach to the existing axle?
    On my Silverado the rear leaf springs attach with U bolts. There is a spot on the tube specifically for it to center the axle easier, but just a simple bit of measuring when tightening down the U bolts would be good enough on a trailer.
    Might have to grind the coil spring perches and the trailing arm mounts off the TB axle, but I'd think you could U bolt it to the leaf springs fine otherwise as long as the axle is also wide enough.
  5. Mirror
    286
    21
    I belive it is u bolted on
  6. Mooseman
    Mooseman Moderator
    10,301
    4,811
    I used a Blazer diff in a trailer I built years ago (still have it). I welded some spring perches onto the diff tubes in the proper positions. I got them from a trailer shop.
    [​IMG]
    Moved to towing section.
    Redbeard and Capote like this.
  7. Sparky
    Sparky Moderator
    10,499
    5,320
    That's the part I couldn't think of earlier. Those would be important.
  8. HARDTRAILZ
    HARDTRAILZ Moderator
    44,534
    11,118
    You can get adapters actually. Plenty of places will custom make any you want. I had to get some done for my dad's Triumph TR8 since no one made wheels for it. They really were reasonable too.
    Or grind off everything, weld up some spring perches on the TB axle.
    Adapters prolly be cheaper and for sure less work
    Tiggerr likes this.
Share This Page
