Hello. I decided to join the site after following May03lt on YouTube for a while now.
Yesterday I went to go start my by and noticed the cluster doing all sorts of weird stuff. The speedo and tach and some lights that will dim still work but nothing else. It had popped up reduced engine power, parking brake, security, battery, and abs all at different times while I cycled the car in and off. It would display nothing for fear selection and odometer at first then it would show me bits and pieces of both.
Then magically it fixed itself until later that day it did it again. I unhooked the battery for a while and nothing changed but I. Prices thugs time the keyless entry didn't work and the drivers door locks and windows wouldn't work. I also slammed the drivers door and the radio would cycle on and off. After that I pulled fuse 24 and the doors locked immediately after but gauges still not working. I put everything back together and closed the hood and saw the gas light went out after a bit and now it all works again except the lights for the speedo. I checked the g201 and g102 and nothing.
I'm hoping somebody has some ideas or knows of a good replacement cluster to get
Thanks
Thanks
