How To: Change Transfer Case Fluid
CaptainKD
31,981
How to: Change Transfer Case Fluid
(Every 50,000 Miles / 80,000 Kilometers)
Items you’ll need:
2 - Auto Trak II fluid; 1 Liter; Part No. 10-4017
1 - Fluid Pump
1 - 3/8” Hex Bit Socket / Alan Wrench / Hex Key
transfer-case-01-jpg.83844
**IMPORTANT** Remove the Fill Plug BEFORE you remove the Drain Plug.
transfer-case-02a-jpg.83845
1. Once the Fill Plug is removed then remove the Drain Plug. Be ready with an oil catch pan.
transfer-case-04-jpg.83846
2. After oil has drained, replace the Drain Plug.
3. Use the fluid plump and put new fluid into the Fill hole. You’ll need 1.8L per the Owners Manual.
transfer-case-05-jpg.83847
4. Replace Fill Plug and enjoy :thumbsup:
:thumbsup:
fletch09
1,982
Nice :thumbsup:
questions that might come up:
is the pump available at any auto parts store, or on line
how hard or easy was it to break the plugs loose?
CaptainKD
31,981
fletch09 said:
Is the pump available at any auto parts store, or on line
The fluid pump I used was from Advance Auto, I'm lucky enough to one 2 minutes from me but similar pumps can be found from Auto Zone and various sites online such as: eBay, amazon, etc.
Here's a link to the one I used:
Advance Auto - Performance Tools Fluid Pump - Part No. W1139
fletch09 said:
How hard or easy was it to break the plugs loose?
This is the 2nd time I have changed the Transfer Case fluid so the plugs were not hard to loosen. I was also using a ratchet which gave me more leverage.
mfnman88
30
Dundee
Just did this on my new-to-me Saab 9-7x (141k miles) and the drain plug came out with only an allen wrench (10mm worked for me BTW). The fill plug however took a lot more. I had to chop off about an inch of the allen wrench and put it in a 10mm socket and used the 2 together with a breaker bar. I was almost hanging on the thing when it popped free. I'd guess it was well over 50ft pounds to get it free. Everything went back together just fine though.
mfnman88
30
Dundee
Don't remember what his pictures were exactly but here's what I can see from laying on the ground next to my Saab. Rusty 10mm allen(hex) plug in center of the picture is the check/fill plug and the one toward the bottom just left of center of the picture is the drain plug. Hope that's what you're looking for.
CaptainKD
31,981
Re uploaded photos......
Items you’ll need:
1 - Fluid Pump
Reactions: rizzo20
Mektek
656
FL
I had a seized fill plug. Heating it, impact wrench. breaker bar - nothing would turn it. I filled it through the speed sensor on the top - plastic threads easily unscrewed.
MissCrutcher
