Great site!! Recently my tb was stolen out of my driveway. It was found a couple days later and towed to a local GM dealer. Minimal damage such as door lock popped out and ignition key cylinder destroyed. The ABS and brake lights are now on so the dealer pulled the code. The tech cleaned the ground wire connector for the module and light still on. Advised I need a new ECBM. Before I do that I can't help but think something was damaged by the thief or the tow truck. Quite a coincidence the light is on after that. I'm thinking of swapping out the ignition switch as I have read here that can be the culprit. However, from what I hear there are usually other electrical problems such as heater fan not working etc when the ign switch goes. Everything works except the ABS/brake lights are on. Would like some advice if it's worth changing that switch or go a different direction. Thanks!
