Help: Abs trouble
black ice
85
The block under the drivers seat with the break lines going into it, would not stop running after the ABS light came on, Had to remove the fuse to get it to stop, tried to put the fuse back in this morning and its still running... thoughts on this?
What do you exactly with "would not stop running "? Do you mean that the ABS is cycling the brakes? Do you feel the pulsation in the pedal? Is it all the time or just when rolling or coming to a stop?
black ice
85
The module with the motor under the driver's seat, would not stop running after i cut the truck off..
Very strange. Will probably need to bring it to a dealer or shop that has a tech2 or equivalent code reader to see what's up with it. sounds like something beyond just a bad sensor.
MissCrutcher
