GRRRR Stupid Power Ports!!
Discussion in 'Technical Discussion' started by l008com, Jan 10, 2017.
  1. l008com
    l008com Well-Known Member
    310
    58
    Tonight was the third night in about three weeks that I had to have someone come rescue me with jumper cables. I got one of those cheap 12v heated seat pads because I'm always cold and my truck doesn't have heated seats. But this truck's two power ports never shut off! Even if the truck is off and locked, the power keeps flowing until the truck is dead! SO you have to remember to turn the seat off or unplug them, something you would normally never do. I usually remember, but not always. It is SOOOOOO annoying. I wish there were some way I could run those ports through a relay or something so they would shut off. I also want to try real heated seats but who knows when i'll have time to give that a go. It's just so frustrating.
    Redbeard likes this.
  2. Sparky
    Sparky Moderator
    10,089
    5,000
    This has been how all my cars have been (4 GMs, 1 Ford).
    I guess others do differently.
    Wouldn't be hard to wire in either another port to an ignition source, or relay one of the two factory ones like you said.
  3. l008com
    310
    58
    My last car was a Camaro, it's ports turned off. I know this because this very heater was in that car (2013) and it would turn off. I think my S10 blazer's ports shut off too.
  4. Sparky
    Sparky Moderator
    10,089
    5,000
    Guess maybe GM started putting switched ports in later? My 98 and 99 Camaros both had always on ports, my 07 Silverado does too.
  5. Blckshdw
    Blckshdw Moderator
    7,568
    6,211
    Splicing in a relay would be easy enough, even easier if you have an aftermarket HU and an interface for it, since it would have a switched output on the harness.
  6. Mooseman
    Mooseman Moderator
    9,150
    4,004
    I used one of these to do the switching to the ports. I used the TCCM fuse as the source since it switches off with the ignition. One fuse spot is for the original (TCCM) fuse, the other for the ports (20A). Stick wire into the now empty fuse connector that supplies the power to the ports.
    You have to remove the piece of plastic in between the two prongs.
  7. l008com
    310
    58
    Do you use that to power a relay to switch the power ports, or do you use that to directly power the power ports? Where do you connect it to?
  8. Blckshdw
    Blckshdw Moderator
    7,568
    6,211
    You connect it to the relay coil, which turns it on/off along with whatever source you tapped into. Some light browsing on Youtube may be in order to give you some visuals on how you'd use them together.
  9. littleblazer
    littleblazer Gold Supporter
    6,386
    3,044
    I think my sisters cruze is always on as well... I find it convenient especially when I am working and leave the phone in the truck to charge between stops.
    You could go switched power from the ignition as well.
  10. djthumper
    djthumper Administrator
    13,425
    3,058
    Admin Post
    Funny, one of mine turns off in both the TB and the Silverado
  11. Sparky
    Sparky Moderator
    10,089
    5,000
    :blinkhuh:
  12. coolasice
    coolasice Well-Known Member
    727
    224
    Yes one of mine does too
  13. l008com
    310
    58
    Which one? Currently both of mine are in use, one as a phone charger and the other as an ass warmer. I know the ass warmer (left port) stays on thanks to all the jump starts. The right port has a 12v USB adapter that has a red indicator LED, so I know it's on 24 hours a day too. Weird. My truck is a 2008, maybe they changed it at some point.
  14. coolasice
    727
    224
    I thought for sure one of them turned off with the rap. maybe i'm wrong... i never use them.
  15. Sparky
    Sparky Moderator
    10,089
    5,000
    On my 02 Trailblazer both ports were always on (I left things plugged in a few times on purpose).
    My 07 Silverado NNBS is the same way - I leave the dashcam running in parking lots all the time, and I had the other port charging my GF's phone at one point.
    Weird.
  16. Mooseman
    Mooseman Moderator
    9,150
    4,004
    No relay required. Just put a small spade connector on the end of the wire and put it into the fuse connector. The other end is fed directly by the ignition switch. Only thing though is that it only turns on with ignition, not aux power. Tried to find one that's on with aux but didn't. This works fine for me. I did it for the dash cam.
  17. dkvasnicka
    dkvasnicka Silver Supporter
    336
    168
    This is also PITA for dashcams that turn on and start recording automatically as they get juice from the outlet... Chrysler did this properly on the old Pacifica - one port always on, the other one tied to ignition.
  18. Mooseman
    Mooseman Moderator
    9,150
    4,004
    It's doable. Just some wiring to do.
  19. jsheahawk
    jsheahawk Well-Known Member
    404
    101
    Yep. Just wire it into an accessory wire under the driver's dash, and it will only be on when the key is. Easy peasy.
Share This Page
