front end problems
03envoy757
4
I have 03 envoy, I have replaced ball joints front and rear sway bars. but still have rattling (clunking) coming from front drivers tire everytime I hit a bump.(slow or fast) I am lost on where to go next. Any help would be appreciated.
Wooluf1952
2,663
Milwaukee, Wisconsin
Did you replace the end-links and mounting bushings?
03envoy757
4
I am sorry I replaced the end links not the sway bar. I have been reading I may need to check the sway bar bushings. I only did the end links.
03envoy757
4
I am going to replace the sway bar bushings first to see if that does it. Thinks for getting me to thinking the right way.
Also check the nut on top of the strut shock shaft. They have been known to loosen up, rarely. Or the upper mount could have torn its rubber.
Another vote for strut mount.
Regulator
2,496
:iagree: I think that is where the issue is.
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
I know a little late but :iagree: on the strut
:iagree: With myself.
javier perez
