littleblazer
- Jul 6, 2014
- 9,265
Woa. That's gotta be the worst slap I've ever heard. It sounds like the 3.0l 4 cylinder with a flat cam in my boat... but slap isn't deadly.I've got a video, with sound of course, of my 5.3 with piston slap. You can have a listen to see if this is similar to what you are hearing.
Thanks for the input but if I recall correctly, it did it without the belt too. It almost sounds like a wrist pin knock to me, which should spell the end or anything. Similar sound to slap you know?@littleblazer that sounds to me like a bad belt tensioner. The one next to the power steering pump, not to be confused with the the idler pulley above the A/C Compressor. Maybe that's worth a shot. Less than $50 to see.
Also might help if you could read live misfire data.
It's a cheap part, either Dorman 419-125 or GM ACDelco 12573024
Nope, mine doesn't sound even close to that, way quieter and it doesn't sound like a diesel like that Voy did.I've got a video, with sound of course, of my 5.3 with piston slap. You can have a listen to see if this is similar to what you are hearing.
You can't really hear it as well with the fan tbh.littleblazer I can't hear anything remotely out of the ordinary on that video... sounds like a quieter version of what my 02 sounded like.
If @Capote's truck sounds like that I'd not worry at all. Mine was easily 2x as loud as that for the entire time I had it from 112k to 215k, particularly when cold. When my exhaust manifold started leaking a bit it was louder, I just called in a diesel wannabe because it kinda had that diesel growl to it
Oh god no man that's not what I got, that's clearly a rod knock.This seems to be an actual Rod-Knock sound ( added here for additional comparison)
Nah sounds different than that buddy. I'll get a video tomorrow of the sound. I just hope my phone picks up the sound accurately as it actually sounds in person.This Guy's Engine sounds like his Timing Chain Tensioner has failed...and judging from the piled up snow on the ground nearby and observing from how readily he races the engine to high RPM... I suspect that if the Engine was literally Ice Cold when he first starts it up...racing the RPM so soon like that in Frigid Climates before the Engine Oil can get warm enough to make its way around inside the Stone Cold Engine Block may have precipitated this problem. Does your motor sound close to this?
Alrighty manI think valve cover gaskets can generally be reused. Nothing is really under pressure there. I'd be tempted to reuse it. Worst case is it seeps a little and you have to replaced it later.
Diesel OilI am always leery of additives, considering them to be nothing more than snake oil. Good oil, oil filters and proper intervals are all you need.
Diesel oil or fuel? I've used Shell Rotella 5W40 T6 oil in the past. Expensive stuff (here anyway) and from what I read, not better than Mobil 1.
Turns out it was like 2006 or 2007 and later that had the redesign. It didn't look like it'd work spacially, so I found a used $30 one that looked in great shape from an '05 Voy. It'll be here next week. The flexplate's are not easy to find for our platform (w/ 4.2's), not in stock even on rockauto or GM part sites. Couldn't even find a proper p/n. EBay was my only luck last night.Let's not jump to conclusions. I know of a lot of people (on various platforms) who have simply replaced their flexplate and never had an issue again. Sometimes, it can just fail.
My 02 never did for whatever that is worth and I haven't heard of it being a routine issue on older engines. Not sure what changed between 04 and 05, and not sure if they're interchangeable.
I'm going to agree with Sparky on this one. I've seen a small number of GMT360s with this issue, and for whatever reason it's typically after the tranny has been removed or reinstalled poorly, or it ripped apart by someone with the mechanical skills of a toddler. I'd say if you've isolated it to a flex plate, replace it and see what happens. It's an uncommon failure.
I'm going to disagree with @MRRSM on this one and his "Catastrophic Failure" theory is really kind of a load of crap, not everything requires ripping the engine apart, and not everything requires throwing hundreds (maybe even thousands) of dollars of parts for a possibility. The original owner of my Volvo put a in flexplate 86k miles and it went to nearly 233k without issue.
Again... I'm not making this stuff up. Watch how the Crankshaft pushes and pulls back and forth against the Flex-Plate. What we can't see here though due to the RED TC being in the way, is how much of that "Coning Effect" is really taking place pushing in and out near the centre of the Flex-Plate bolt up flange stressing and work hardening the mild steel....Seeing is Believing:As if the engine itself would be the cause is kinda ludicrous IMHO. Possibly an issue with the torque converter might.
Don't throw out the baby with the bath water.
Yeah I've had my transmission out 3 times already. This'll be 4 times now. Torque Converter is a remanufactured one.@Capote did have his tranny out a few times if I recall correctly - very possible (probable?) something one of those times happened to the plate after mounting/dismounting so many times. That's why I said to not jump to blaming the engine right away, given the transmission history.
