FAQ: Towing
This sticky is for links to the most asked about questions, info, specs and general knowledge related to Towing.
If you see a thread that should be considered to be added here, click on the <Report> button with a note indicating that it should be added.
Transmission Coolers..
Adding a Tranny Cooler
Towing Mirrors
Tow Mirrors Installed
What's the limit?
How to install an electronic trailer brake controller
Brake control mounting
Tekonsha Prodigy P3 Brake Controller Install How-To
12V charging/aux line in trailer connector
Red Wire (The disconnected ring connector near battery/underhood fuse box)
what gear for towing? (also towing capacities)
Need diagram of 7 pin towing plug
Reactions: streetbober
06_4.2_4x4_ls
