FAQ: Suspension & Steering
This sticky is for links to the most asked about questions, info, specs and general knowledge for the suspension and steering.
If you see a thread that should be considered to be added here, click on the <Report> button with a note indicating that it should be added.
Suspension
Front Swaybar Link Replacement
How to Replace TB/Envoy rear shocks stock or Tahoe shocks
How to: Replace front wheel hubs and upper ball joints.
How To: Lower Ball Joints GMT360 (Missing pics)
Z71 Springs ??
Sway Bar Links Clunking and Clunking when hitting bumps
Where to find OEM bump stops
New Shocks/Struts Question (Brand)
Rebuilding the front suspension
How to replace upper ball joints and front wheel hub on a GMT360
Bilstein rear shocks
Replacing lower ball joints
Lower Control Arm Bolt Size and Part Number
Replace 4 Ball Joints, 2 Tie Rods and 2 Stabilizer Links
Front and rear spring rates with color codes and part numbers
How to replace front lower strut bushings
Air Ride Suspension (Air bags)
How to: Replace Air Suspension with Coils
DIY rebuild of Air Compressor Check Valve - 0$
Rear Air Suspension and Compressor Replacement
Help with air bag height adjustment
Rear Air Suspension Compressor Mod?
Air Compressor Not Turning On To Fill Air Shocks
Another air ride thread (No pressure)
My experience with Arnott Air Bags / Air springs
Steering
How to change a steering gear (rack and pinion) for I6 EXT 2006 4WD trailblazer
How to Replace Outer Tie Rods
Steering Racks across models
Outer tie rod boot torn....replacement?
Help with Steering Angle Sensor?
Inner tie-rod ends (Replacement)
Procedure for replacing return power steering hose on 2003 trailblazer
Reactions: Tiggerr
Firebaugh86
