- May 28, 2014
- 15
Welcome to my nightmares...
Two years ago I needed to change out the temp sensor and when I did I also changed the T-Stat and water pump. Fan clutch seemed to be ok so left it in there. Apparently I didn't clean under the T-Stat well enough and the damn thing started leaking. Took it all apart, cleaned the debris and new O-Ring and back together. This time the water pump bearings were going again so changed it out as well. Seems the bearing on the clutch were taking them out so decided to change the clutch with a new one, Korean Eristic from eBay. Looked good but after all that assembly it sounded like jet taking off. Played around trying to get it to work but it just wouldn't release. Another aftermarket, this time a new Dorman and it seems to have released just fine as the jet roar is gone now. BUT, now my A/C doesn't work and blows hot air. I also noticed the temp doesn't seem to get to normal operating temps. Could there be an air lock from changing the T-Stat and the sensor is playing tricks with the ECM?
I wish I would have checked here first damn it but I have serious health issues keeping me from functioning as I have in the past. It just seemed like an easy in/out...
