- Aug 12, 2015
- 7
I have been lurking around enjoying all the information. I have a recently purchased 2002 Envoy XL SLT, 4.2 L, 128,000 miles. It was running a bit warm, 220 to 240 on the gauge, at highway speed, fine other wise. Changed thermostat and hoses, no change. Checked fan clutch, seemed to be working. Decided to let wife drive it on a 2 week, 2000 mile trip. The temp was not much of an issue, did better on the flat land to the north. Used oil, lots of oil. Other than needing about 3 GALLONS of oil to get home, it did great.
Mechanic determined we had big time ring blow by. Installed a 100K mile used engine, runs great, no SES light.
So, it still runs a bit hot, stays at 210 running around town, will go to 220 to 235 (first big hash past 210) at highway speed, A/C off does not change much.
- I discovered and did the burping procedure today, no change.
- have the new 198 deg thermostat on new engine.
- new water pump at engine change.
- i ordered a BAFX Bluetooth code reader and got Dash command for the phone, will get it next week.
While doing the burping thing I watch the coolant moving around, seems a bit milky and some very small flecks in it. I will do a radiator flush next. Should I switch from the green mix with anything premix which is in it now, to pink Dex cool? Any other cool ideas?
