- Jul 24, 2012
- 833
How will I know when I have the right amount of fluid left in the transmission?
So I had the transmission cooler lines replaced and the fluid seems to have been overfilled. At least, the slippage has moderated as I have slowly removed fluid from the system. Performance was consistent with an overfilled transmission at least as far as I have read. Engine speed was bouncing pretty aggressively at speeds above 45mph. I have been slowly pulling fluid out and seeing how it works.
Had the truck on the road for a camping trip this weekend and I noticed that when I am running down the freeway at 75-80 and the tach is at 2K-ish, I don't have any problems. And no problems in slower speed situations.
But when the transmission is hot and the throttle inputs are a little more vague, like I'm maintaining a speed of 55 on a flat stretch, the engine speed will pop up and down a couple hundred rpms. Sometimes it will lug a little, sometimes there's some shudder that I can't attribute to road conditions.
Now, I was kind of hard on the transmission. It took me a while to grudgingly admit that I needed to have someone do the cooler lines for me, and I dropped all the fluid a couple of times, so there may be some damage.
I can keep taking fluid out, and I've read here in a couple of places that the dipstick is basically useless ... but how do I know when the fluid is probably right on and if I still have issues that it might be some other cause?
