Transfer case fluid changed out Thursday and Full Synthetic oil change done today.
Tomorrow or Monday Tranny fluid change. So I ordered the Dorman oil pan with drain plug https://www.amazon.com/gp/product/B002U6ELS4/?tag=gmtnation-20
Read the reviews and it seems the drain plug gasket might have an issue with leaks, so I ordered the Dorman 65270 drain plug gasket https://www.amazon.com/gp/product/B000C11GKA/?tag=gmtnation-20
Those that have done the Dorman oil pan, have you had any issues with the drain plug gasket? Did you just move over the magnet from the old pan to the Dorman since it doesn't have one?
Tranny filter will be replaced https://www.amazon.com/gp/product/B000C9LOHW/?tag=gmtnation-20
The new tranny filter comes with a filter seal, Ive read some change it out, while other leave in it. They say it can be a little tricky to get in and if not done correctly could damage that area. Any thoughts?
I have 4 gallons of Dexron VI, I assume this will be enough for a fluid change to clean via the tranny cooler lines?
Lastly since I am changing out the 1-2 3-4 Shift Solenoid Valves the vehicle should be in park and not Neutral?
